Home › Forum › Ask A Member › JW 22 Starting Problems
- This topic has 11 replies, 5 voices, and was last updated 2 years, 3 months ago by
JACQUES.
July 8, 2024 at 9:05 am #288940
Newest motor I ever worked on.
Mid sixties compression
Tanks is clean, filter clean, new fuel flows freely. Carb cleaned ultrasonically, blown, new parts, bowl fills. New mag parts. Great, bright spark on both new plugs. Choked. Won’t even fire. Plugs are dry and clean. Shot some carb cleaner directly into carb. Fires and runs on the first pull. Removed and checked carb. Full of gas. Why isn’t the fuel getting into the manifold?
July 8, 2024 at 9:15 am #288942Did you inspect the reed valves?
Crankcase sucking air?Prepare to be boarded!
July 8, 2024 at 9:48 am #288943Arg!! I can and will check the reeds but how do I check if crankcase is sucking air?
July 8, 2024 at 11:46 am #288948piece of paper in from of the carb or kleenex should show air being sucked in.
did you clean the top drip chamber under the dime size plug and that sneaky little side channel feeding fuel to the top idle fuel chamber ??
if fuel does not make it to the top of the carb chamber and out 3 small drip holes it will never start
July 8, 2024 at 12:22 pm #288953I an upper crankcase bushing and/or seal is bad, one can
test by pouring a little oil around the crankshaft, and turn
the engine over slowly with a wrench. If you see bubbles
in the oil, repairs are needed.
Of course, if an upper crank bushing or bearing is bad enough,
you can feel “side play” in the flywheel.Prepare to be boarded!
July 9, 2024 at 10:46 am #288997OK, so it starts up if you inject fuel/fluid into the carb, correct? Once started, how does it run and idle? If it runs and idles nicely, then I gotta think that the choke isn’t working correctly.
Another question: Once you have run it for awhile and shut it off. Will it restart OK?
What kind of fuel are you using?
July 9, 2024 at 11:10 am #288998The only thing I didn’t change is that dime size plug. Just cut corners for time. This carb has no high speed jet. I rebuilt it as I would and have any carb. But I’m thinking they had to change something else when they eliminated that jet. Maybe that’s my problem but I will pull that aluminum plug first.
This is a JW 22. Do you think a carb from an earlier model, say JW 17 might work?
While at this, here is another problem. I set the JW 22 aside and cleaned up a JW 16. Lower end seals, etc. Mag was good but I rebuilt it’s carb using the same foreign carb kit that I used on the JW22. Hooked everything up, opened the fuel valve…and…fuel poured straight through the carb and onto the floor. What the…..???
July 9, 2024 at 3:39 pm #289000if the carb is clean and theengine has no cc vacum leak no reason not to start ..
jet orifice needles all the same they must be clean .
flooding mean the float is snagging or inlet jet not working properly…works like a toilet bowl !!!
July 10, 2024 at 2:05 pm #289029The only thing I didn’t change is that dime size plug. Just cut corners for time. This carb has no high speed jet. I rebuilt it as I would and have any carb. But I’m thinking they had to change something else when they eliminated that jet. Maybe that’s my problem but I will pull that aluminum plug first.
OK, I’m confused. Let’s not get too deep into this and create more confusion. How does the engine run once started? If it runs and idles nicely, a plugged up carb seems very unlikely. How does it start after shutting it down for a few minutes?
Did you check the choke linkage? How far are you advancing the throttle when trying to start it cold? If you are starting it in the “start” position, perhaps the cam pick up is not set properly and the throttle is closed…But, I think these carbs open the carb a bit when the choke is on, so maybe cam pick up is not an issue here.
July 10, 2024 at 11:06 pm #289050Did you take carb cleaner and spray it through the fixed jet? It should be located in the fuel bowl. I had a problem like this on another brand recently. There was a white powder plugging the jet. Needed a wire to clear it out.
