Home › Forum › Ask A Member › JW 12 R
  • #17265
      did a quick check. 80lbs compression spark on top cyl only. looking in the inspection plat on the flywheel the coils points and condensers look pretty new will have to pull the flywheel and clean the points and check the rest. just for kicks I pulled the choke and on the 2nd pull it fired for a few seconds looking good. now I will set it aside till I get time for it.
      #17268
      Hugh Long
        80# is strong for those. Should make a good runner
        AKA Outlaw Outboards in Fallon, Nv
        Now in Twain Harte, Ca
        #17279
          I’m not used to 80 mercs are 120. but I knew they should be good with 80 from what I have read here.
