Home › Forum › Ask A Member › Just a thanks
  • #2245
      Ijm Moffit,
      Thank you so much for the contact data with Bob Long. Anyone need a Scott-Atwater impeller made Bob is a great manufacturer. Just got it in the mail & it is very nice & quite usable!
      Thank you two,
      Jeff
      #21921
      RICHARD A. WHITE
        What????? Scott-Atwater impellers???? say it aint so…. PLEASE share that info!….LOL
        Need a set for my 33 hp
        Regards
        Richard
        classicomctools@gmail.com
        #21923
        Leon
          I need a set for a 7.5
          #21942
          Casey Lynn
            And I will need one at least for Lesa’s 16hp.
            #21951
            vintin
              I need one for my 1960 60hp Flying Scott.
              #21959
                Here you go. There’s enough for everyone!
                http://www.ebay.com/itm/HUGE-WHOLESALE- … 88?vxp=mtr
                #21973
                  Jim,
                  I’m not sure if my 1952 Firestone 10hp has the correct drive pin as it extends enough to contact both sides of the impeller installed. This requires a square channel[ 180 degrees apart channels for both pin ends to make contact but gives a 100% better drive for the impeller. I also see a round ridge on the impeller blades for sealing the top & bottom sides like a Mercury impeller blades as well. Contact data is as followes. The early impellers had a a nylon center hub too. It will well for a very short life. A brass impeller hub must be used on all of Bob’s service work too. Please let Bob know if you have a many paddle impeller or a Hockey puck type or is for the the bailer housing . I too have used Bob’s impellers that have worked very well too in my 3.6, 7.5, 5 & a 54 10hp Firestone cooling. Once again his address, I don’t have his phone number at the shop. If you need anything else email at Jeff.50@cox.net.
                  Bob Long
                  325 Washington street north/east
                  Building 433
                  Olympia, Washington 98501
                  /size]
