Home › Forum › Ask A Member › johnson tn 26 gas tank question
  • #262276
    pandajack
      the tn26 gas tank i have is dented but my question is the attached gas tank the same as a tn 28 or similar models
      • This topic was modified 4 years, 4 months ago by pandajack.
      #262278
        TN models tanks have two vertical holes through them.  One for the carb adjust knob, and the other for the neutral clutch lever.  TD models have no neutral clutch, therefor no clutch lever nor hole for it.
