Home › Forum › Ask A Member › Johnson XR55 POwerhead Rebuild
- This topic has 21 replies, 2 voices, and was last updated 1 year, 10 months ago by
TOM GOEPFRICH.
December 18, 2016 at 10:42 pm #5921
I’m rebuilding the powerhead on my XR55. I’m not sure if there is something I’m missing to release the crank from the case? Bill Salisbury had told me at one time about a snap ring, but I cannot see it for the life of me. Any thoughts? Due to rarity of this motor, don’t want to force anything!
Randy, If I send the gasket manufacturer these gaskets could they reproduce them for me?
December 18, 2016 at 10:44 pm #49376I just noticed too the piece I broke as shown in the pics. If anyone has one they would sell I would obviously be interested. If not, I could probably have one cast.
December 19, 2016 at 12:01 am #49383Chris,
If that broken bit is the detent for the magplate, I would bet that it is common to other motors.December 19, 2016 at 12:49 am #49385Yes it is Adam. Hopefully it is the same as the V series, or even others as well. Ill compare it to my V45s
December 19, 2016 at 1:19 am #49387December 19, 2016 at 1:29 am #49390Yes you are correct Jim. There was a bolt in there to lock the center main. I removed it.
Im not sure if it is just simply pressed in slightly and tight, I don’t want to force it.
Plus, I remember Bill telling me to remove a snap ring, which for the life of me I cannot find. I don’t doubt him on this vintage powerhead, he knows his stuff!
Speaking of Bill, has anyone talked to him lately? I hope he is well.
December 19, 2016 at 1:31 am #49393December 19, 2016 at 1:48 am #49394Thanks Jim!
Figure 21 shows the snap ring Bill talked about Im assuming. Ill have to figure out how to remove it without any special tools.
Which manual did you find that in? Im sure I have it, is it the 1922 to 1955 manual?
December 19, 2016 at 1:55 am #49395I’m glad to see you are getting back at this motor. If you end up needing that part cast let me know. We fired up the new furnace today and made some Tee Nee emblems. We will be sandcasting periodically from now until spring.
Wayne
December 19, 2016 at 4:27 am #49405quote Chris_P:Which manual did you find that in? Im sure I have it, is it the 1922 to 1955 manual?
It came from a manual at the Austin Sailor site. Not sure what year as it’s titled 20’s to early 30’s Johnsons. -
