Home › Forum › Ask A Member › Johnson TSL20
  • #3336
    ausob-collector
      Hi all
      The other day I went and got myself a Johnson, with the model as TSL-20.
      There is not much info about them around so I was wandering if anyone could shed some light on it.
      It is painted army green and I came across another post on iboats forum with someone else having the exact same with army green.
      Were they used in the armed forces?
      I have the date of manufacture as 1946 but I have seen it listed at 1945 and 1944…
      Any help appreciated.
      Thanks
      BP
      #29728
      hotrod
        The TSL-20 came out after the TSL-15. The TS-15 was made 1941-’45, with the TS-20 coming out in 1946 according to our Johnson guide book. There is a military manual for the TSL-15 which has about everything you could want to know in it. It has 63 pages in it divided into 3 parts: Operation, Maintenance, and Parts. It is illustrated, and the manual number on the dark green cover is TM5-8002. The -15 is nearly identical with the -20 except for the crankshaft and magneto. The letter ‘L’ in the model number means long shaft.
        #29735
        ausob-collector
          Hi all
          Pics of the Johnson.
          Hotrod, thanks or that info. You wouldn’t by any chance have a pdf of that manual?
          As I intend to restore it both cosmetically and mechanically, does anyone know the correct decal design for this motor or have an advert for it I could use?
          Cheers
          BP
            Hey Aus! PM me your email address and I can send you a PDF copy of the TM5-8002 manual!
            #29741
            unclebud
              I have a TSL-20 also and could not get any info on it other than 1946. Somebody had panted it camo so I striped it and pain ted it sea mist green. Mumbles, I would like a copy of that manual if You don’t mind, I will PM You.
              #29751
                Done!
                #29809
                unclebud
                  Thank You
                  Art
