Home › Forum › Ask A Member › Johnson tn28 water stream question
  • #4895
    scottw
      I am still looking for the "outlet" near the bottom of the cylinder head where a water stream should be present to verify the water pump is operating. I see all sorts of videos online that show this stream near the low speed adjustment needle but I can’t see an outlet hole for the stream on mine. It appears to be a hole drilled into an elbow but I don’t know the hole diameter. Any thoughts?
      #41403
      fisherman6
        It should be a drilled hole in an elbow just as you said. It is quite a small hole if I remember correctly. I have a TN-26 in pieces. If I get a chance this evening I can try to get a picture if no one has posted one yet. It seems like the hole is around 0.03" or so.
        -Ben
        OldJohnnyRude on YouTube
        #41404
          Yes, a small hole drilled in the bottom corner of the copper pipe elbow. I don’t know the diameter off-hand. Probably somewhere between 1/16" and 3/32" as a wild guess.
          EDIT: Written at same time as Ben was typing. At least we agree.
          #41405
          steveh
            It is a very small hole and is easily covered with paint, grease, etc…
            #41407
            scottw
              Wow, thanks both of you guys for responding quickly. Hopefully, it is a thick layer of paint that is obstructing the hole. I bought this motor from Craig’s list and the previous owner had recently painted it. If no hole is present, I’ll drill one. The motor right now seems to run well for 5-8 mins at top end then slowly decreases rpm’s until stalling.
              #41410
              2fast4me
                Scott, is your vent open on the gas cap? Is it plugged with old varnish? Fuel flow will stop with that vent being restricted.
                Jim
                2Fast4Me
                #41415
                Leon
                  I wouldn’t drill it out, because it’s probably already present. Just take a small wire and clean it out.
                  #41418
                  fisherman6
                    I would not recommend drilling it out either. Unless someone replaced it with another elbow, the hole is already there. I’d try some lacquer thinner on the elbow until I found the hole then clean it out with a wire or something. If the water pump is working the powerhead will still get cooling water regardless if this tell tale hole is flowing. On the other hand, just because this hole shows water flow does NOT mean the powerhead is seeing the cooling water. I believe on these motors this hole is actually in the system BEFORE the water passes through the powerhead. Someone correct me if I’m wrong on that. Flow at the tell tale shows the pump is pumping but that is really all it tells you in this case.
                    -Ben
                    #41441
                    scottw
                      Gentlemen,
                      Thanks for all of your input. After grinding away the paint….. and using a small wire… Here is the hole that was missing. Another issue has arisen, The motor is leaking with the petcock for the fuel turned off. It appears to be leaking in the junction where the primer pump and the top of the carb meet. The original owner of the engine was kind enough to take a look at it.
