Home › Forum › Ask A Member › Johnson TN Stuck, where to start?
  • #239816
    wanderlustjake
      I just picked up a Johnson TN last night. If I try to spin the prop, it has zero movement but I can feel just a hair of movement (like a gnat hair) grasping the flywheel. It was the seller’s Dad’s and he knew nothing about it. Is there anything with the neutral clutch that could lock it up? Just curious if there are any “high flyers” to check out first on these motors?
      Thank you.
      #239826
        dropping te GC gets complicated cause you need to disconnect the neutral cable… try popping the fw as a starting point cause you need to inspect the coils anyway (likely all cracked)
        you will need an impeller so dropping the GC can come later anyway and… maybe the clutch is broken diagram TN GC1 ..
        . and this will tell you if the blockage is above …or below in the GC πŸ™‚
        shoot some wd40 in the cylinders just is case but stuck rings would probably stop ANY movement worth a try
        next could be the cyl. head to inspect the cyl walls and pistons
        after the mechanics are fixed comes the carb …
        http://www.pochefamily.org/outboard/CarbService.html
        is it a TN 26 -27 ???
        • This reply was modified 5 years, 5 months ago by JACQUES.
        #239828
          It wouldn’t take long to remove the prop and cap off the gear case
          to see if it’s full of rust instead of grease.
          wanderlustjake
            It’s a TN25. Thank you, as soon as I have some time I am going to dive in on it.
            #239847
              see info
              #239850
                see TN GC 2
                #239855
                wanderlustjake
                  Crosbyman, Thank you!, those will help!
                  #239873
                    as a aomci member you would have access to download the 400 or so pages of the johnson repair manul covering oldies… from your TN td and up to late 50s
                    it is in the MEMBERS ONLY section under INNER SANCTUM…LIBRARY…Garry Spencer’S drop box…. down the file is a RED BOOK…. where the pictures provided come from πŸ™‚
                    #239928
                    wanderlustjake
                      Yes, I have realized joining is a must do and will be shortly. Thank you again.
                      #239948
                      wanderlustjake
                        I am now a member : )
