Home › Forum › Ask A Member › Johnson TD-20 primer pump seals
Viewing 3 posts - 31 through 33 (of 33 total)
  • #272375
    richard maxon
      This is great.  I am in the process of rebuilding the carb on a TD-20, which I purchased off ebay.  However, it seems the primer is also missing the brass washers.  Having difficulty finding, thoughts?
      Also would you mind providing any pictures and the part numbers for the tools used to create the leather seals?
      Thanks so much,
      rich
      thanks,
      Maxonr
      #272387
      LLOYD LAUTNER
        Making those leather primer seals so they work properly is not as easy as it sounds.  Making the special convex and concave brass washers would be very difficult  and essentially impossible without the originals to provide correct dimensions.  I have some parts motors that can provide what you need.  I would call you so we can discuss your project but your name is not listed in the 2022 Members directory.  Give me a call and maybe we can get you what you need.   Lloyd    231-929-7479
        #272395
          Are you sure they are gone? If the brass tube stops
          flush they are still in there. If it keeps going then
          the washers are gone.
