Home › Forum › Ask A Member › Johnson T Series Brass primer cylinder
  • #8309
      Has anyone ever looked for, and found brass tubing stock to make
      new primer cylinders for the H and T series Johnsons?
      The cylinder on the DT-38 I’m working on fought removal
      for all it was worth. I finally won with soaking, heat,
      and a 1/2" tap, but it was not pretty when it came out. 😮
      I "could" scavage one from a TD or the likes, but thought
      I’d ask if anyone ever "made" new ones.
      The tubes are .500 ID, and about .562 OD.
      I find tube stock for sale, but all .500 OD.
      Thanks!
      aquasonic
        I don’t know about making them, but a few years back, Marine Engine had them for sale for around four dollars.
        Improvise-Adapt-Overcome
        #65352
          Thanks, I’ll check it out!
          Update –
          The part number for the brass sleeve is 132158.
          The only place I found that had them was a
          marine dealer in CA, via EBay, that wanted
          almost $20 each with shipping.
          I’ll borrow one from a junk TD 😉
            maybe something in the plumbing section could do … ?
