Home › Forum › Ask A Member › Johnson Ship-Master controls – Part Number ??
  • #3186
    John
      I am looking for the manufacturers part number for the plastic gear rail
      for the vintage ’60s Ship-Master controls. I found the drawing but no part numbers.
      Also, the little brass clamp that has two small set screws.
      With a little research, it seems none are available unless you buy the whole assembly off of e-bay.
      My local machine shop can make them and they are priced by the man hours
      put into the tooling set up. If there is any interest or demand, I can have a dozen
      made at one time. Don’t know the price per each just yet.
      #28696
      ED
        The rack p/n is 303238 and available approx MSRP $13
        cable clamp p/n is 303219 which supersedes to 385958 p/n contains two set screws and clamp approx MSRP $13
        If interested in parts, send me a PM
        #28782
        ed-sam
          The part no for the remote control complete less cables is 377781
          The part no for the rack is 303238
          Ed
          #28784
          jw-in-dixie
            Can’t see the detail – is it a Allen socket? Can you make one out of a screw and saw a screwdriver slot? Just wondering.
            #28785
            John
              it is a 1/16" hex allen screw. It is so small, I would not
              cut a slot for a screw driver as you need a LOT of torque
              to hold the wire in place so it won’t slip. Plus, it is recessed about 1/32" into the barrel.
              Just buy the proper tool for the job – thus eliminating the frustration factor.
