Home › Forum › Ask A Member › Johnson serial number HP/year reference guide…?
  • #3075
    johnyrude200
      I think I know the answer to this, but does anyone know of a johnson serial number guide to identify HP/years?
      Obviously you can use the ID plate on the transom bracket, but I run into a lot of transplant motors or ones where the ‘dog tag’ is gone (either the metal one, or…really?…the STICKER that is used on newer motors).
      Im hesitant to even rely on orifice plugs in carbs due to how many folks like to try to turn smaller HP motors into bigger ones when they arent really meant for that with a simple carb swap.
      Thanks gang.
      #27770
      retiredoz
        My recollection is that Johnson serial nos are not associated with HP ratings, unlike Mercs. So the best you can get from serial no is year of manufacture…
        #27772
          Ive never seen one published, for the public. Never seen any pdfs or such floating around.
          There is the small serial number guide, for Johnsons, in the Old Outboard Book, which covers years up to ’64.
          #27775
          johnyrude200
            Well serial #’s associated with years would be helpful at the very least. Help narrow down the field a bit.
            I guess, other than warrantee reasons, not sure what the point of the numbers would be beyond that though.
            #27786
              Here is all you ever wanted to know about year of mfr. Well, almost. Imported ones not always included.
              http://www.skoterskroten.com/img/arsmodellstabell.pdf
