Home › Forum › Ask A Member › Johnson Seahorse TN28 Timing off?
- This topic has 35 replies, 15 voices, and was last updated 10 years, 10 months ago by
Buccaneer.
December 2, 2015 at 7:36 pm #27937quote John C:Have you tried squirting some fuel mix into the spark plug holes and seen that it will pop that way?
I’ve done this before the carb was working correctly and got no results. I am going to try this again tonight that I have the carb working.
December 2, 2015 at 8:00 pm #27939I’m starting to suspect the fuel mix. Or you have plugs that won’t fire under compression. Maybe it’s time for some NGKs ?
December 2, 2015 at 8:20 pm #27940quote retiredoz:I’m starting to suspect the fuel mix. Or you have plugs that won’t fire under compression. Maybe it’s time for some NGKs ?I’ll check the fuel ratio again, if I can’t get anything after spraying starter fluid into the cylinders it has to be spark plug related. I will swap those out next. Any reference on which NGKs?
December 2, 2015 at 8:39 pm #27941quote mikele86:quote retiredoz:I’m starting to suspect the fuel mix. Or you have plugs that won’t fire under compression. Maybe it’s time for some NGKs ?I’ll check the fuel ratio again, if I can’t get anything after spraying starter fluid into the cylinders it has to be spark plug related. I will swap those out next. Any reference on which NGKs?
Champion J6J are recommended back in 1952… NGK B6S are recommended today for replacement. I may already have these plugs 😐
December 2, 2015 at 9:39 pm #27945Do not use starting fluid. it is no made for use on most two-strokes. I would replace the plugs with the correct Champion J-6C plugs and I’m betting things may fire.
Greg
December 2, 2015 at 10:35 pm #27946OK, back to basics. You say it has an entire new ignition system and has spark. Define spark. Will it jump a 1/4" open air gap?
December 2, 2015 at 10:56 pm #27948Anonymous
Have You checked out the Poche family website?
http://pochefamily.org/outboard/December 3, 2015 at 3:11 pm #27969Update: Completely wrong spark plugs… 😳 can’t believe it took me this long to notice the size difference from the original ones..purchasing the RIGHT pair tonight, I’m almost sure this thing will start right up now. will let everyone know. Thanks again for all the advice!!
December 3, 2015 at 3:12 pm #27970quote Steve A W:Have You checked out the Poche family website?
http://pochefamily.org/outboard/Yes, this guy did an excellent job. I must of read through a few of his articles a dozen times by now. Thanks!
December 3, 2015 at 3:13 pm #27971quote gjonz:Do not use starting fluid. it is no made for use on most two-strokes. I would replace the plugs with the correct Champion J-6C plugs and I’m betting things may fire.Greg
You may be right Greg 😀
