Home › Forum › Ask A Member › Johnson Sea Horse 10
- This topic has 20 replies, 17 voices, and was last updated 7 years, 5 months ago by
LLOYD LAUTNER.
June 2, 2019 at 11:41 pm #176557
Dang it man, what a find!! I’d also buy it in a heartbeat if I was anywhere near you. If it’s not locked up it could easily fetch $200+
"Every time you remove a broken or seized bolt an angel gets his wings."June 4, 2019 at 7:51 pm #176639I love it. The 54 QD-15 is my favorite Johnson 10hp and that one is a beauty. I’d pay up the 200 bucks for that one in a heartbeat. It’s about 5 hours away from me so it’s a bit far for one motor, but it is pretty awesome. I’m sure I could have that motor running perfectly in an afternoon.
-BenOldJohnnyRude on YouTube
June 5, 2019 at 4:53 pm #176684June 6, 2019 at 1:29 pm #176740I believe that was the only year they had the Sea Horse cast into the exhaust housing – yes, it is a museum piece. In order to get it running in top shape would at least require coils, capacitors, carburetor rebuild kit and water pump impeller. It may also involve replacing rubber parts such as fuel lines, seals and high voltage ignition wires.
This reply was modified 7 years, 5 months ago by
garry-in-michigan.
June 6, 2019 at 2:20 pm #176742Nice, very nice. I have three,, but not anything like that. Nice!
2Fast4Me
June 6, 2019 at 3:50 pm #176746The sea horse was cast in the lower unit in ’53 and ’54! It does look nice on those oldies!
dale
June 6, 2019 at 3:56 pm #176747I believe that was the only year they had the Sea Horse cast into the exhaust housing.
I thought there were two years with the sea horse cast into the housing…. At least there are two different green QD’s in that photo with the sea horse housing!
Gary– I know Johnson isn’t your thing!! Have you considered writing a memoir about you and your family and Evinrude? Maybe the club can help find a “ghost writer” to help put it together????!
http://www.omc-boats.org
http://www.aerocraft-boats.orgJune 7, 2019 at 9:03 am #176782I only repeated what I was told when I first saw one like that at a meet. Obviously that was wrong. . .
I had posted a brief outline on the Florida Chapter’s old web site. I don’t know what happened to it.
June 7, 2019 at 9:18 am #176783It is beautiful
June 9, 2019 at 1:28 pm #176943Great looking motor! For about $75 in parts (coils, water pump impeller, condenser and maybe points) it should run great. May also need lower gearcase seals. I have one like that but someone painted the case all green – and didn’t replace the graphics. Note that the gas tank – if you have it, can be worth almost as much as the motor in some parts of the country.
Dave -
