Home › Forum › Ask A Member › Johnson RDE-16 green formula ?
  • #4402
    jethro
      I tried using the search function but did not give me the needed info…
      Looking for the mix formula for green used on johnson rd/rde-17 – I think 1956-57-59 (?)
      I guess there is also an off white that goes with it too—-
      (if I only have the color name– will my paint guy know how to look that up ? or do I need the actual proportions.. ? — im thinking yes… )
      Can anyone supply a link for these ?
      Thank you-
      Tim
      #37427
      johnyrude200
        reprotint has replacement paint, as well as NYmarine out of canada. If you don’t have a gravity fed paint gun, you’ll need someone with some experience to repaint your motors since these sources sell it by the quart (generally about $60-80/quart). The stuff in the cans (if available) is a lesser quality option…just make sure you spend 85% of your time on the prep stage (cleaning up, sanding, priming, taping off, etc).
        If you go to the members section there is a whole area on restorations with much more info than what I could ever offer!
        #37430
        jethro
          Great !
          I will web-search those two paint hits ! Thank you !
          Yes- I grew up restoring classic cars- so I got paint guns ! I would probably use the hardener and gloss addative that Tractor supply sells for
          tractor enamels. It makes for less overspray and makse the paint a lot harder and tougher after about 3 months when its FULLY cured.
          I wouldnt even consider a rattle can. They aernt allowed to use fully effective solvents (EPA) in rattle can anything (including chromate)
          so the final product seems to have piss poor adhesion compared to liquid-in-a-can automotive style paints.
          Thanks- i will look those up !
          Tim
          PS
          I see I need to become a member here !
          #37451
          Leon
            I would go with rthe reprotint. It’s a perfect match to the original color and the price is a little more reasonable.
            #37455
              I have used a lot of paint from nymarine. Good product.
              http://www.nymarine.ca
              #37456
                quote 1946Zephyr:
                Zeph,
                Not sure where you got that from? Think you may have it backwards. Im not trashing reprotints paint at all, heard nothing but good things about him and his product. I would like to buy and try a bunch of colours he has….but NYMarine paint is not more expensive.
                A pint of paint at repro is $47.95 US, NyMarine pint is $37.95 Cdn, or only $28.97 US.
                12 oz spray can at reprotint is $19.95 US, NyMarine is $15.95 Cdn, or $12.18 US
                #37509
                Leon
                  You’re in Canada, right? If thats the case, then yea NY will be your best bet. I repainted the lower unit on my 1955 RD-17 a little while back, after I re-sealed it and the color matched the original paint on the exhaust housing, very nicely. I was very impressed
                  I have had great results with NY’s products, as well. Don’t get me wrong.
