Home › Forum › Ask A Member › Johnson racing prop for Mercury super10
  • #6489
    GARY HIRSCHLIEB
      I recently obtained a Johnson brass racing prop made in Oakland, Calif. that will fit a Mercury Super 10 Hurricane. The prop has two small round indents in the rear, the prop is not splined. I heard there is an adapter that will fit into the prop with two pins and is splined to fit the Mercury prop shaft. Is this correct? Are there any of these available? Gary in Michigan
      #53986
      John Schubert
        I have the adaptor. contact me at jschubert19j@gmail.com
        #53987
        RICHARD A. WHITE
          What is the bore of that prop? Any numbers on it? I have one of the spline adapters as well…but looking for a speed prop for my KE7 that is a smooth shaft
          classicomctools@gmail.com
          #54081
          GARY HIRSCHLIEB
            Richard; I’ll check I might have a spare speed prop for the KE7 smooth shaft…I’ll get back to you…gary
            #54089
            RICHARD A. WHITE
              quote hirschlt37:
              Please do, and thanks
