Home › Forum › Ask A Member › Johnson QD rod/piston swap
  • #6849
    shoestringmariner
      Hey folks, Another thread opened my eyes to the vast size differences in the rod & pin sizes in the 50’s through early 60’s QD’s.
      The thread states that you can use the 58 and down rods with earlier QD’s, but did I hear in another thread that the 61-63 rods will work as long as I use the 61-63 pistons?
      I have a 54, 57 and 58 that I’d like to restore, but better.
      If this conversion works, will I be able to get away with a leaner mix ratio also?
      #56678
        I have done quite a few Scott.
        They idle real nice, start with ease. I highly recommend the conversion.
        Yes, get all of the items from a ’61 to ’63
        I think I have done a thread on this conversion with everything listed that you would need.
        #56679
          Here is what you will need
          Wrist Pin 307849 x2
          Connecting Rod 378330 x2
          Piston 378285 x2
          Needle Bearing 378251×2
          Big End Needles 378150 x2
          Piston Rings 378416 x2
          Circlips 302577 x 4
          #56696
            I would stick with the recommended 24:1 mix.
            #56703
            shoestringmariner
              Thanks Chris. Edit; I misread your post – thought you had the parts. I appreciate the shopping list however
              Thanks Fleetwin. I thought I read that OMC went to 50;1 in the mid 60’s. Thought it might have something to do with a full roller set up. Love the classic motors, want to make them run cleaner if I can though
