Home › Forum › Ask A Member › Johnson qd-20 cooling question
- This topic has 8 replies, 5 voices, and was last updated 4 years, 1 month ago by
hondaatc.
September 8, 2022 at 6:29 pm #265735
Hey fellas i just picked up a qd – 20 the guy i purchased it from said he had recently replaced the impeller after only a few short minutes of running it in the bucket i noticed it spraying water out of the exhaust port like normal but it wasn’t much of a spray and it wasn’t steady the head was hot to the touch so i removed the thermostat housing cover and thermostat started the engine and nothing pumped out i did notice water also coming out of two holes on the lower unit ( see photo .. red circle ) this is the first outboard i own with these holes also saw water seeping out of the shift linkage access cover any advice or info would be appreciated before i start removing and inspecting the impeller… thanks
September 8, 2022 at 8:14 pm #265745You will normally see water coming out of those two holes on the side of the lower unit. There will also be water in the exhaust stream and if it’s seeping out the shift linkage door, you just need a new gasket on access door. If you pull the lower unit to check the impeller, check to see if the impeller plate is sealed to the gearcase housing – if not, they will sometimes not pump properly. Also, with the lower unit removed check to see if the water tube up to the powerhead is clear (not obstructed) and see if water will flow up the tube thru the powerhead. Finally, there could be an obstruction in the cylinder head water passage preventing a full flow of water. These are some of the things I have found in the restoration of my QD-19 and QD-20 motors.
"Every time you remove a broken or seized bolt an angel gets his wings."1 user thanked author for this post.
September 8, 2022 at 8:52 pm #265747Thanks i will definitely check that out i did use my garden hose and sprayed water into the thermostat housing and water came out the exhaust hole
September 8, 2022 at 9:34 pm #265749One more thing I just found on my FD-12 restoration – when I pulled the lower unit I found the last person in there before me didn’t get the water pump grommet and water tube aligned correctly when they installed the lower unit. The water tube grommet was mashed down on one side and that will prevent the proper flow of water. See attached pics.
September 8, 2022 at 10:55 pm #265755Thanks again I’m hoping to have time to pull it apart this weekend hopefully its something like what u have found
September 9, 2022 at 5:51 am #265759When you run it with the thermostat cover off, a LOT of water should come out. In addition to the many good tips of BobW, I would add that, if someone “replaced the impeller” but didn’t notice a badly worn impeller housing, sometimes they will pump WORSE with a new impeller in a bad housing. This is apparently because over time, an old impeller sort of form-fits the worn housing to some extent. A new one won’t fit the wear patterns as well.
September 11, 2022 at 11:06 am #265864If the impeller was changed but no water is coming out of the thermostat location, that indicates a blockage somewhere between the pump and the upper powerhead. Quite possibly the old impeller was broken and not all of the pieces were accounted for when it was replaced. A piece of impeller vane can be lodged in the copper tube leading to the powerhead or could be caught under the block or in the passages under the exhaust cover. Either way, the powerhead should come off to find the blockage.
September 11, 2022 at 2:01 pm #265875try forcing air or water up the water tube. see what happens. can’t hurt.
September 18, 2022 at 11:11 am #266266Thanks fellas I’m gonna Tear into it soon looks to be a nice outboard besides that
