Home › Forum › Ask A Member › Johnson PO-15 year made?
- This topic has 12 replies, 5 voices, and was last updated 10 years ago by
garry-in-michigan.
October 10, 2016 at 10:50 pm #5471
A Johnson PO-15 followed me home day.
I find information that they were made
from 1941 to 1950. (were they made during
the war?)
Can someone point me to serial number data
so I can determine the year made, having
serial number 869483 ?Thanks!
October 10, 2016 at 11:30 pm #45594Looking in The old Outboard Book by Peter Hunn the serial number is very close to the end of 1950.
October 11, 2016 at 12:00 am #45597SydinNJ is on the money with his answer.
Just thought I’d add, your PO-15 appears to be one of the very last.
PO-15 last year of manufacture was 1950. PO-15 serial number range for that year was 787,025 to 869,939.
Regards,
SpiroOctober 11, 2016 at 12:33 am #45603Thanks guys! Guess they should have had all the
bugs out of mine by 1950!
Were they produced during the war for the military?Mine is very dirty, looks like it’s been sitting outside
for a while. It’s missing the carb and prop. Flywheel
has nice rebound. I see nothing cracked, broken or welded.
Is there anything in particular on the PO-15’s to be on
the look out for?Hopefully moister hasn’t done a number on the crankshaft
with the carb being off…. even though it had a rag stuffed
in the hole.Is there any "digital" parts diagrams, manuals, etc., "Out There"
for the PO-15 ?
Thanks, BuccPrepare to be boarded!
October 11, 2016 at 4:13 pm #45617Here’s a parts manual.
October 11, 2016 at 7:43 pm #45626Awesome! Thanks Mumbles, much appreciated!
October 11, 2016 at 7:43 pm #45628The PO Johnson built for the Army/Navy during WW2 was a longshaft reversing model that was used to push barges and maneuver pontoon bridge sections. Official model designation was POLR 15. Many were sold in 1945/46 as Army Surplus…
October 11, 2016 at 8:20 pm #45633October 11, 2016 at 10:26 pm #45643Thanks Mumbles. I see I’m missing the "stop button", as
well as the carb and prop.
I checked compression this AM, after a shot of WD-40
in each cylinder, and had about 95 psi on each cylinder.
Is that okay for this engine?Prepare to be boarded!
October 11, 2016 at 11:49 pm #45649I spent the last hour reading the Antique Outboarder archives on Johnson
PO articles from the 1970’s. I took some notes for future reference,
seeing how I’ve never had or ran a PO.General Information-
Check flywheel torque occasionally, they have a habit of losening?
Spark Plugs- Champion R-7 (replacement D9J)
Points – .020
Piston Rings part number is 29-10, still available from OMC in 1973
Low speed jet plugs easy, inline filter recommended
3/4 pt / gallon oil to fuel mixture recommended, or more for heavy useGear Lube- Texaco 950 (thick, black, water proof)
Fill from bottom, in hole marked "grease" until it comes out the hole marked "vent", which is above the cavitation plate. (An inspection hole plug is below the cavitation plate.) The hole marked "Drain" is a water drain.
There is another plug, just above where the lower unit foot attaches to the drive shaft housing. If labeled, it will be marked "Drain", but it’s a drain for excess fuel that passes the lower engine bearing. It should be drained every 5 to 10 hours of running.Starting – High Speed Needle 3/4 turn open, Low speed needle 1/2 turn open
Mag lever 1 or 2 notches right of center
Set choke all the way closed on full choke models *
Close throttle
Open compression release
Rock flywheel (with rope) about 10 times, (to charge cylinders with fuel) then pull through to start
When started, go to 1/4 choke or so
Close compression release (all the way to left)
Don’t open throttle until warmed up a little bit
Adjust high and low speed needles as needed
*On the earlier PO-15’s with the cut-away choke carburetor, you can prime engine by pushing down the float pin, and may not even have to use the choke.Prepare to be boarded!
