Home › Forum › Ask A Member › Johnson PO-15 Prop Size?
  • #46031
      I’m guessing then there will be "no" water flow when the PO is
      in a test tank? ……. I’d probably have to use the engine hoist
      to even get it in the test tank, lol.
        I queried the seller of this prop regarding size, pitch, and
        prop shaft bore size.
        http://www.ebay.com/itm/361447084376?_t … EBIDX%3AIT
        that the seller states is
        the OMC prop number 375581 as suggested in this thread
        that I need for my PO-15.
        The seller replied…….
        The inner diameter of the propeller hub is .75". The diameter measures 10". The only information we have about the pitch is what is stamped on the prop itself. It says : 56164 x 4
        Questions –
        1. Is the center bore of these props "stepped"?
        Such as 3/4" on the outside end to fit the treaded area of the prop shaft,
        and larger in the rest of the bore? I believe I measured the prop shaft
        on my PO as .892, and odd size!
        2. Does the seller’s # 56164 x 4 that’s on his prop translate to any meaningful
        information, such as pitch, etc?
        He states it’s about 10" diameter. Not sure if I should hold out for a larger
        diameter prop?
        Thanks for any data or thoughts!
          The prop that came with the early ’50s 25 horse Evinrude Big Twin/RD Johnson is 277580 – 10-3/8" by 12-½". It is used as a heavy duty prop for cabin boats and barges for the 40 horse model. The six digit numbers that replaced the old Johnson numbers with the dash in them were in the 306 and 307 range. Of course those could be superseded by newer, higher numbers. . . 🙂
          #46241
          GARY
            Have you checked with Doug Penn?The 10 3/8 diameter will work fine and was the standard prop.The 12" will push more water for cooling when you are operating at low speed,but you don’t troll with a PO.
            #46245
              If the 10-3/8" prop will work fine I guess I won’t worry. Don’t think it
              will get a lot of use unless I get a dedicated boat for it!…… too heavy
              to be taking it on and off the boat, and I think my lightweight AlumaCraft
              would sink!
              It was stated on the thread that…. "Your original 29-175 prop measured 12 X 13",
              so I wasn’t sure 10-3/8" would be desirable.
              Thanks!
                Going a bit deeper into the Johnson parts book, I found a few more listings for PO props.
                Confused yet? I am, as I don’t have any idea what diameter or pitch they are! 😕
                ftruntz
                  The Michigan Wheel catalogs on the Green board will provide a good amount of information. Props will be identified with pitch and diameter along with reccomendations for application. Michigan props only; however.
                  #46264
                    Mumbles, thanks for the information…. I think, lol.
                    I’m guessing the Cavemen did a lot of experimenting before
                    they figured out what size rock worked best… lucky
                    for them they didn’t have to deal with props!
                    Will Look on the Green board data. Thanks!
                    Randy in Tampa
                      Michigan wheel AM 33 is the fastest prop for light boat with two people but the AM 31 and 32 are also good props, I have tried all three …. 😎
                      quote Buccaneer:
