Home › Forum › Ask A Member › Johnson P-30 connecting rods: top or bottom
  • #282957
    GARY HIRSCHLIEB
      Restoring a 1926 P-30…..and everything is going great; right & left  cylinders/pistons. But now for final assembly: as you face the motor…which connecting rod goes on top and which on bottom??  I never thought about this….if you look into the situation they seem to be interchangeable?? I’m thinking it doesn’t make a lot of difference…or did I miss something?
      #282958
      Tom
        It does make a difference.  If it’s wrong, you get spark when the pistons are at the bottom of the bores.  Pistons should be at top dead center with the keyway pointing to the arrow cast into the top of the crankcase.
        Tom
        #282959
        GARY HIRSCHLIEB
          I understand that, I’m talking of where they connect to the crankshaft….
          #282960
          Tom
            Are the pistons still attached in their original configuration?  If so, the longer slope goes toward the exhaust port.  If you are just looking at bare rods, I don’t think it makes a difference.  Best to check in both configurations to see if one binds up.
            T
            #282961
            GARY HIRSCHLIEB
              You are correct….I apologize…when I thought about it, the arrow will place the crankshaft in the correct position, and when I install the piston/rod assembly for TDC that will determine the connection to the crank.  Right?  I did check binding and they are OK.
              #282962
              Tom
                Yep.  Evinrude is similar on early twins, except the keyway points forward.  This would be on N Sportwins and R Fastwins.
                T
                #282966
                GARY HIRSCHLIEB
                  Thanks for your…much appreciated…
                  #282968
                  Tom
                    Great motors, they run pretty well.  Good luck!
                    T
                    #283038
                    GARY HIRSCHLIEB
                      Another question you can likely help with…the piston pins are pinned to the piston with what I believe is a cotter pin. Correct?  After inserting it, how do you spread the pin legs?  Just get creative?
                      #283041
                      Tom
                        I usually go through the hollow piston pin with an awl to get it started, then a screwdriver to set it.
                        T
