Home › Forum › Ask A Member › Johnson of Oakland, Kaminc, and Stannus Props
  • #3073
    handyandy
      I saw a box of bronze props at an antique store. With the wife. There were at least two Johnson of Oakland, a Kaminc, and Stannus propellers. Are these inboard or outboard props. Most seemed small for inboard use, maybe 8" diameter.
      Johnson S34 and H11
      Kaminc MC 4633
      St. Annus 1439
        I hope you bought em!
        I would have to look up the numbers. I have a few Oakland props, for my Speeditwin.
        #27763
          If the bore is tapered, they’ll be for inboard shafts but the smaller props also used a straight bore with a pin.
          The old rental clinker boats from around here had small props on the brass shafts. I guess it was a good match for the single cylinder Briggs motors that were spinning them.
          I have one with a short piece of shaft out in the shop so I’ll measure it when I go out there.
          #27769
          handyandy
            It would be helpful to have an idea of the application of these props. If they are for outboard motors and can be of use to members, I will pick them up.
            I have the following application table for Johnson Propellers that someone posted awhile ago, but no propeller numbers, only dimensions. If someone has a list of applications by prop number, please share!
            ADAM GIBB
              They all look like left hand props, so they would be mercury or Evinrude speeditwin/speedifour 22.5/33 hp"
              A couple look similar to ones that I have for my speeditwin. The kaminc is probably mercury.
              I would grab them and post the ones you can’t use here. I would be interested in Evinrude props if available.
              #27780
                kaminc is keikheafer aero marine inc. mercury for sure.
                #27909
                handyandy
                  Well I went back and made a deal. Turns out an older couple brought them in; they had owned a marine service business and these were take-offs for repair/replacement. A couple have bent tips or chips off the trailing edge, but most appear in good shape.
                  I have one ID’ed for sure. It has the OMC part 100726. The 1945 Evinrude Service manual says this is the standard for Models 905-907 Elto Special Speedster 9 HP 1931-1933.
                  Others to be identified:
                  Michigan KD5 (8.5" diameter, have not measured pitch yet)
                  Kaminc MC 4634 7" x 10 (marked)
                  Stannus 1477-1 8.5" diameter
                  Stannus 1477-2 8.5" diameter
                  Stannus 1429-1 8.5" diameter
                  Unmarked 9.5" diameter
                  Johnson of Oakland 8 1/2 (marked 8 3/4") x 12 1/2 (marked)
                  Johnson of Oakland 8 3/4" (marked 9") x 11 1/2 (marked)
                  Johnson of Oakland 8 3/4" (marked 9") x 11 (marked)
                  Johnson of Oakland 8 3/4" (marked 9") x 13 (marked)
                  #27916
                  gil
                    The KD5 is listed for a KG9……8 3/8 x 14 $18.90 new
                    #27917
                    John Schubert
                      It looks like the Kaminc’s are quicksilver props for KG7H’s or MK20H’s. If you bought them I’d be interested in purchasing them from you.
                      #27943
                        I too collect these. Any you are interested in selling please PM me.
