Home › Forum › Ask A Member › Johnson MS38 "Suasage Tank" overheating
  • #3716
    bob-d
      Hi all, my MS 38 started to overheat. I took it apart and checked that the two ball were not stuck, and found a perfectly symmetrical round hole in the water tube running up to the head. It is perfectly round, so my question is, should it be there, or did the tube just corrode and a chunk came out, which prevented a good flow of water to go to the head? I am thinking the latter. If so what would be the best way to repair, solider, JB Weld?
      Thanks,
      Bob D
      #32532
      bob-d
        Sorry, that was suppose to say solder.
        Bob D
