Home › Forum › Ask A Member › johnson model MJWF22C
- This topic has 8 replies, 4 voices, and was last updated 6 months, 2 weeks ago by
Don.
April 22, 2026 at 9:39 am #316150April 22, 2026 at 9:44 am #316152
Just remove those 4 flat head screws below the white band, under the tank….that will let you take off the lower cowl… Nice motor
classicomctools@gmail.com1 user thanked author for this post.
April 22, 2026 at 11:05 am #3161571967 Johnson JW-22 3 hp Outboard Motor Parts
MJWF22C
maybe… M means military ??? grade ??? somebody knows ! the above link for a JW22 had a FOLDING model listed
looks pretty much like the folding JW pull the flywheel check coils for major cracks, clean contacts change condensers and gear oil
2-3 drop of oil of the felt pad rubbing the crankshaft ! Check fuel filter inside fuel tank and check closely in the fuel cap for holes for proper venting..
carb likely needs a clean-up to
should last another 50 years GREAT kickers for trolling and NOT ROWING 🙂
download this free book to service it ….covers all oldies from late 40s to mid 60s incl your JW !|!! print locally and bind 🙂
https://www.socalaomci.com/library/johnson_service_manual_10th_edition.pdf
bible for johnson and evinrudes ( cousins)
Outboard Motor Carburetor Repai
April 23, 2026 at 4:56 pm #316269thank you
April 24, 2026 at 11:29 am #316329Just remove those 4 flat head screws below the white band, under the tank….that will let you take off the lower cowl… Nice motor
Is there a screw in the carrying handle that must come out also in order to split the lower cover apart??
April 24, 2026 at 11:32 am #316330And yes indeed, this is a nice motor…. Please be very careful with the case, they are delicate and will break/crack easily, especially with age. You must be very careful about how you pick it up/set it down as well. That little tip at the bottom of the gearcase skeg can be very delicate, very easy to snap it off. Once that piece gets snapped off, the gearcase will no longer clamp in the folded position….
April 24, 2026 at 2:16 pm #316346Good catch Don, fergot that one, dag nabit…lol
classicomctools@gmail.comApril 24, 2026 at 3:08 pm #316353see parts diagram link provided it shows a bolt to split the handle if you have to.
these small kicker can get real hot is a tub because if they run fast and they whip cream the water the aerated water does not cool them to well.
pulled the FW yet to check coils and all electricals ?
April 24, 2026 at 11:49 pm #316392Good catch Don, fergot that one, dag nabit…lol
Oh well, I’m sure I will omit something soon, I always need a safety net from other members…
