Home › Forum › Ask A Member › Johnson Model A flywheel removal trouble
- This topic has 26 replies, 12 voices, and was last updated 10 years, 1 month ago by
steveh.
March 21, 2016 at 11:07 pm #3889
Trying to pull the flywheel off of my project model a Johnson and having a bear of a time so far. Watched Doug Penns youtube video and he made it look so easy lol,i always get the difficult ones. Tried the wood block and prybar route while giving the crank nut a whack to no avail-except to jar some rust particles loose in the water cooling passages in the cylinders. I don’t like whacking something that old and possibly brittle with a hammer in fear of breaking it. Anyone have any tips for getting the cover off one of these engines? Been looking thru the prior 86 pages and not finding what i’m looking for.
March 21, 2016 at 11:32 pm #33764viewtopic.php?t=3712
March 22, 2016 at 12:58 am #33765
March 22, 2016 at 9:44 am #33773Make up a little nut and bolt system as in Wedgies picture to match the threads on your crankshaft. Tighten up the two nuts on the bolt and then run it down snug on the top of your crankshaft making sure the bolt has bottomed out on the crankshaft. Support the weight of your motor by the flywheel and then hit the bolt hard like you mean it. Don’t play around. Give it a hard hit with your hammer. The flywheel should pop right off. Don’t worry as you won’t damage the threads on the crankshaft doing it this way.
By the way, this is page 87. ☺
March 22, 2016 at 12:43 pm #33783Anonymous
Here’s a video from Mr.Tubbs;
https://www.youtube.com/watch?v=RWgE9XiIBnkMarch 22, 2016 at 1:21 pm #33789A "Boathouse Repair" is one thats done without having tools or the skills to do it properly.
This reply was modified 7 years, 12 months ago by
Tubs.
Tubs.
March 22, 2016 at 10:04 pm #33800Thank you for all the helpful advice. Yes Tubs I did booger up the top 2 crankshaft threads which warranted a trip to Sears for a nice set of tap and dies of which I didn’t have so I guess there was a bright spot to it in the end. I stopped by the hardware store and picked up a 7/16-20 bolt and 2 nuts of the same size. I haven’t gave it a try yet as after the boogered up threads I thought it best to walk away for a while. When I put this nut/bolt combo together tomoro and attach it to the crankshaft should the nuts be touching the flywheel or stop just before? And Mumbles what are you supporting the weight of the motor by the flywheel with-blocks of wood?
March 23, 2016 at 1:02 am #33810Anonymous
Yeah…. I am not a supporter of using a hammer on the flywheel nut & crankshaft to pop the flywheel loose.
I am aware that there are some service manuals that mention this method, but the risk of damaging the threads
on both the nut & crankshaft is high in my opinion. Even if it is sucessful once or twice it does stress & fatigue the threads.
Working on motors regularly I feel having the right tool is key. Flywheel pullers come in all shapes and sizes or you
could always make a puller to fill your needs if one is not avalible as I have needed to for my Rowboat motors.
It’s unfortunate purchasing a motor to restore and finding you have to address a damaged crankshaft due to
a hammer mechanic.Just another view point.
Respectfully
March 23, 2016 at 2:40 pm #33827A "Boathouse Repair" is one thats done without having tools or the skills to do it properly.
Tubs.
Tubs.
March 23, 2016 at 10:23 pm #33836Try heating the hub of flywheel until wax will melt and be drawn into area between flywheel and crankshaft. A no harm and surprisingly effective technique. Worked for me and maybe for you
as well.
Louis -
