Home › Forum › Ask A Member › Johnson model a condenser
  • #292449
    mike n
      Hello, does anyone know of a condenser i can use in my 1924 johnson model A. Thanks
      mn
      #292450
        Here’s a chart
        Eary-Johnson-Condenser-MFD-ratings
        mike n
          Great! I knew i saw that somewhere. Thank you. Is there an off the shelf condenser that i can use
          mn
          #292453
            These are the two I use. Tubs
            #292454
              mike n
                Thank you all for the help
                mn
                #292596
                T….in Wisconsin
                  Informative and helpful article.
                  I swapped out the original coil on my 1936 Handtwin with (2) BRP 58477 coils.
                  Dressed the points, has new plugs, wires and original condenser that tested @ .11uF. Spark is blue but not very impressive.
                  Being that I changed to the new BRP coils should I also use a .22uF condenser? I’m currently waiting on a .11uF capacitor to put in the original condenser can.
                  Please advise on your thoughts which option may be best.
                  T..
                  #292604
                  T….in Wisconsin
                    NAPA can get both of these.
                    Echlin is $17.04
                    Standard T-Series is $ 19.00ish
                    #292607
                      there is a relationship between coil and condensers but te critical aspect seems to be moreĀ  magnetism generatedĀ  Ā andĀ  it’s impact on the coil windingsĀ  not to mentionĀ  protection from arcing across points.Ā  Ā  Ā trial an error I guess with your new set up using modern coils on older magnets
                      but m. Mohat seems to like the middle ground using .22 uf
                      Joining AOMCI has priviledges šŸ™‚
                      #292609
                      GARY
                        This is from series of Antique Outboarder articles (written by Bill Mohat) concerning testing and selecting condensers.I run .22uf and higher in my early A models
