Home › Forum › Ask A Member › Johnson LT10 grounding brushes
  • #6984
    woodyp
      I am looking for a set of ground brushes part# 71-1499 for my 1940 LT10. I believe that they are made fm .010 thick phosphor bronze sheet. I can’t find sheet brnz this thin or I would make my own. These hook to coil and contact rotor on flywheel.
      Thanks, Terry Plank, Woody3040@gmail.com
      #58825
      lakeofwoods
        Find some ? If not i’ll send a picture and see if this is what your after next week.
        #60034
        jw-in-dixie
          Could you use brass shim stock? Just wondering. An LT10 was the first motor I operated at age 8 in 1940. A sweet motor. Still have one. Cheers, JW
          #60261
          woodyp
            It needs to be spring temper bronze
