Home › Forum › Ask A Member › Johnson LT-38 cooling
  • #296834
    rkjjeep
      This 1938 LT-38 has the plunger pump that runs off a cam on the propeller shaft.  Everything was clean and all balls were in place – what is the best way to tell if it is pumping water when running in a tank?  Thanks
      #296838
        If you’re running it in a test tank or lake with cool / cold water, you
        should be able to feel the copper water line by the powerhead
        and feel the cold water pumping through.
        Also, some people drill a tiny hole in the lower elbow where the
        copper line attaches to act as a “Tell – Tale” to see the water
        shoot out.
          Another option is a laser  temperature gun . They can be found for around $10.00. They’re not super accurate. Mine seems to be about 3 degrees low but its close enough for my needs.
          Gun
          #296843
          CHUCK
            RKJ…You have a PM.  (Private Message)
