Home › Forum › Ask A Member › Johnson LS37 compression
Viewing 10 posts - 11 through 20 (of 25 total)
  • #229337
      https://youtu.be/4IfPx8HWYE0
      • This reply was modified 5 years, 9 months ago by Tubs.
      • This reply was modified 5 years, 5 months ago by Tubs.
      #229349
      Mike M
        Thanks so much.. I have sent off for the primer seals.. I will make sure the check valve is not stuck !! great information.. the fogging oil that mumbles recommended didn’t seem to increase the compression so I went ahead and took her apart one of the rings were stuck.. the video you have guided me threw the process of freeing it up.. it was the top piston ring.. will I need to replace the rings or can I use the ones I got? Don’t have a lot of experience in this area so I don’t want to screw up the piston.. any advice would be much appreciated.. thanks
        #229350
          #229444
          Mike M
            Would anyone know were I could get a set of LS37 piston rings? Thanks
            #229448
              #229450
              James McGrath
                Hello… I have an LS38, I think like the LS37. I need some very good pictures of the vertical carb control rod, the on with the spring on it. My motor is missing this completely including the little block. I need to find one or make one. Think you may be able to help? Thanks Jim 813 340 5565
                #229459
                Mike M
                  Hope this helps
                  D901D4BB-F362-40E9-BA58-43D2461E2F13
                  • This reply was modified 5 years, 9 months ago by Mumbles.
                  #229477
                    #229831
                    James McGrath
                      Thanks so much. I have to make one or find one. Can you give me the exact distance between the two mounting pins? Jim, Clearwater FL.
                      • This reply was modified 5 years, 9 months ago by James McGrath.
                      #229836
                      Mike M
                        Here you go
                        DE9F5F2A-E033-42AE-9AD3-4A1BA4339891
