Home › Forum › Ask A Member › Johnson LS-38 flywheel issues
  • #259896
    nabmd
      I’m working on this ’38 Johnson LS-38. I noted 2 cracks in the iron ring on the inside of the flywheel. See pics. I do have spark that jumps a 1/4-inch open air gap.  The ‘other’ end of cracked piece is attached to the flywheel at the magnet, so there are no ‘free’ pieces that will come off. What can/should I do about this? It is not going to be a daily runner, but I’d like to be able to use it occasionally. NABMD
      #259929
        Can the crack be ground out and welded without ruining the magnet?
        #259939
        HARRY D. NICHOLSON
          For piece of mind, I would buy a parts motor with a good flywheel, or look for a flywheel which should be cheaper, easier, & safer than welding it.
          #259940
            A flywheel from an LS or DS motor will be a direct replacement.
            LS-Flywheel
            #259944
              Sources for parts would be Doug & Matt Penn
              Link – https://www.oldoutboard.com/
              You could also place a want ad here in the
              classified section.
              #259956
              nabmd
                I did place an ad in the classified; and I have the Penn’s business card in my rolodex. Thanks!
