Home › Forum › Ask A Member › Johnson Lower Unit Gears
  • #280730
    I have a Johnson LT39 that we are preserving as found but would like to get it running. In the lower unit the driven gear is not connected to the propeller shaft is any way. Looks like it may have been a press fit that has given up. Can anyone comment on how this was originally fastened and if there is a fix.  Don
    #280742
      I have a LT37, which has spines that the gear goes on.
      I’ve never seen an outboard that had a gear press fit on a shaft.
      abcdriveshaft2
      JOSEPH BRINCAT
        The OP was asking about the prop shaft gear.  I too have never seen a gear press fit to either a prop shaft or drive shaft. Look real close for a pin that may have been cleanly sheared off.
        #280745
          I’ve seen 2 types. The ends of the spring
          (or the cartridge) engage into a hole in the
          pump cam and a hole in the prop shaft gear.
          #280746
          JOSEPH BRINCAT
            Tubs to the rescue again… I just found a parts list for the LT and was going to ask the OP to look for a hole in the face of the prop shaft gear. There is a spring shock absorber unit that connects the gear to the pump eccentric. In the parts list drawing it looks like a simple coil spring. Tubs first photo seems to be a enclosed unit, last photo the plain spring. Apparently, the OP has a part missing or broken.
