Home › Forum › Ask A Member › Johnson KR-55 Carburetor
  • #190178
    ADAM GIBB
      Did the KR-55 use a Tiliotsen or Johnson Carb? Does anyone have a photo of a correct carb?
      Thanks
      Adam
      #190188
      squierka39
        The original carb was a Johnson carb, part number matches that of the standard K-50. But, the tillotson replaced that quickly when they were converted to run on alcohol . An adapter is used to mount it. So, both carbs are used on a KR-55.
