Home › Forum › Ask A Member › Johnson KA-37 Piston Rings Part Number?
  • #284554
      Anyone have a superceded part number for piston rings…..
      27-25
      Thanks
      MIKE SIMS
        Buc,
        I have a price book from 1972 only shows 27-25 as N/A
        #284724
          Buc,
          Thanks, Al Klebeck had a 1964 pdf with parts numbers,
          and it showed no superseded part number for those rings.
          Someone suggested that Scott 7.5 or 10 hp rings would work,
          but I haven’t checked it out yet.
            The Scott 3.5 and 3.6 hp single cylinder motors seem to have the
            same 2-1/8″ bore as the Johnson K’s I’m working on, but
            does anyone know if those rings are 1/8″ thick, like the Johnsons?
            The Scott 463-1877 rings don’t seem readily available.
            Anyone selling them?
            Boonie
              Hey Buccaneer. Did you ever find rings for your KA 37?  Any info would be helpful. Looking for a connecting rod as well.
              #293489
              TOM GOEPFRICH
                Have you tried “ringspacers..com” ? Usually $5.00  per ring plus postage.
                #293496
                ED
                  Have NOS rings  May have con rod, need to verify part number  Ed Elliott   eddelliott@cox.net
                  #293528
                    Here’s my notes from the KA-37 regarding the piston rings…..
                    9.3 HP
                    2-1/8″ bore x 1-31/32″ stroke
                    13 pint gas tank capacity
                    Champion R-7 spark plug
                    Weight, 64#
                    Compression (with fogging oil)
                    85 psi in both cylinders…
                    but I found the bottom piston had
                    one ring missing.
                    Rings are 2-1/8″ x 1/8″
                    1-26-24, I ordered 4 Maytag rings
                    of that size.
                    Note: Maytag rings were about .013 deeper,
                    so I relieved the inside of the rings a
                    few thousands with a Dremel & stone.
                    Note: Replaced the four Maytag rings with Scott 3.6 hp
                    rings. Compression after 15 second run, T-95, B- 98 psi.
                    baron0418
                      You might try Otto Gas Engine works in Elkton Maryland. I have purchased rings from them for some time
                      #293637
                      T….in Wisconsin
                        I ordered Johnson ‘A’ rings from him last May, sent a check and sample ring. Haven’t been able to get in touch with him in months.
