Home › Forum › Ask A Member › Johnson K50 Lower Unit
  • #6269
      Hey There! Does anyone have an exploded view of the Johnson K50 (or comparable) lower unit? Seems like I’ve looked everywhere a person can look. I have the X-section, but could really use an exploded view…..My mind works kind of like that, if at all! Thanks!
      #52412
      sydinnj
        Here it is if I figured this right
        sydinnj
          sydinnj
            Let me know if this works, I could not get it to post and be seen
            #52418
              Looks good to me. . . 🙂
              #52428
                Many thanks!! I’ll see if I can get that thing apart without parts flying everywhere. Seems like I read in an AOMCI post that there is a spring involved in there somewhere.
                #52455
                Tom
                  You should wait until someone posts the exploded view of the propshaft. IIRC, there is a spring clutch in there. The brass ring that compresses the spring is often cracked or broken from over torquing.
                  Tom
                  #52486
                    Thanks Tom. You’re correct, the nut was broken straight across the bottom. The spring was broken in the middle. Looks to have been broken for years before the motor was retired. As I posted later, a machinist/welder seems to think the nut is broken so cleanly and evenly it can be repaired. I’m looking for the method of proper tightening and securing it. Thanks for your reply.
                    #52487
                    Tom
                      I’ve heard that the cones can be pinned together, and the spring left out. Then a brass pin used at the prop in case it hits something.
                      Tom
                      #52488
                        I’ll have to go back and take a look tomorrow to understand the "cones". There’s a brass pin in the prop shaft at this point. I’m trying to get an idea how tight that bronze nut needs to be. Also, there’s that screw and lock nut in the back that moves the rear shaft bushing. That bushing was wedged solid….no adjusting that, so I finally drove it out, emeried it up and it moves like it’s supposed to. I guess that adjusts the ball bearing clearance. I really appreciate your time.
