Home › Forum › Ask A Member › Johnson K45 piston/cylinder
- This topic has 9 replies, 6 voices, and was last updated 9 years, 7 months ago by
garry-in-michigan.
March 14, 2017 at 10:05 pm #6541
It looks as though the wrist pin came loose and put grooves on both sides of the cylinder and piston.
Looks like the wrist pin was held in place by some kind of cotter pin that fell out. I know I’ll probably need another piston and cylinder but wanted to check with you all to see if there’s anything else I should be wary of?
Thank You
GlenMarch 14, 2017 at 10:37 pm #54338Yes it was a cotter pin. I have seen this on some of the 1930 era Evinrude Fastwins that I have worked on.
March 15, 2017 at 2:29 am #54353March 15, 2017 at 4:04 am #54357Would I need to find another cylinder close to the bore diameter as the other cylinder to make it a decent runner?
March 15, 2017 at 2:59 pm #54377In a perfect world the pistons and cylinders would be the same size but that doesn’t happen all of the time. I’ve come across several multi cylinder motors with one cylinder bored larger than the others and they seem to run just fine.
March 15, 2017 at 11:44 pm #54389Thanks Mumbles that’s good to hear. One of our members wants to try and sleeve it and maybe match a piston to it.
If that works out all I need is a coil, condenser, muffler, several missing and broken pieces a lot of elbow grease and
I’ll be in business. I’m a glutton for punishment LOL..March 16, 2017 at 12:39 am #54394when you put it back together, make some Teflon buttons for the ends of the wrist pin. If the cotter key fails again at any time, the Teflon buttons prevent the wrist pin from walking out of its bore and gouging the walls.
Hope this helps.
Best,
March 17, 2017 at 12:36 pm #54446PM T2,
You can’t use buttons on that engine….exhaust ports are on the bottom..
Regarding cotter pins, I have seen too small of a pin used because the holes in the wrist pin and the piston bosses don’t line up perfectly and prevent the correct size from going all the way through, so folks use a smaller pin. I encountered this on a motor recently. So before installation in the motor I put the wrist pin in, aligned the top hole perfectly with the wrist pin hole and then used the correct size aircraft drill and drilled through. Using too small of a cotter pin allows the wrist pin to rock and eventually the cotter pin breaks….ugghh.
March 17, 2017 at 11:31 pm #54485I found around 20 different kinds of stainless steel cotter pins online. Could someone recommend a good choice to use in the wrist pin? I make everything complicated.
March 18, 2017 at 1:20 am #54497The web between the ports was wide enough to support the wrist pin, it should be fine with a teflon button. . . 😉
