Home › Forum › Ask A Member › Johnson K 45
  • #3616
    mercuryman
      I am trying to get a K45 running what is the starting setup on the carburetor and where do you set the mag lever.
      Thanks
      #31774
      b-morrison
        set the lever just past center. Close gently the high speed needle and open to about 3/4 open and if you have spark, you should be able to find a starting point. Mine starts at 1/2 to 3/4.
