Home › Forum › Ask A Member › Johnson K 45 carb
  • #2849
    mercuryman
      I took apart the carb. on my K 45 and found the float pin bent. Is there a safe way to straighten it ? It looks to made of steel.
      George Emmanuel
        Fortunately, that is the best place for it to bend. It should straighten out easily,—just bend it carefully. Even if it is not perfectly straight, it will work well. If it breaks, let me know….
        George
        #26063
        bob-d
          Mercuryman, does your motor still have the exhaust release valve lever on the steering handle?
          Looking for a picture.
          Thanks, Bob D
          #26065
          mercuryman
            NO, cable missing also lever
