Home › Forum › Ask A Member › Johnson JW23 M
- This topic has 7 replies, 7 voices, and was last updated 6 years, 1 month ago by
melugin.
October 2, 2020 at 11:19 am #217689
I have a 3hp Johnson JW23 M that was gifted to me to use on my old jon boat. The motor was very well kept and only needed a basic service. I’ve since had it running(in a barrel of water of course!) and am hoping to take it out on the water this weekend. I’ve been searching for information, but have only been able to find parts manuals and the diagrams on parts websites. Would anyone happen to have access to a PDF of the owners manual?
Thank you,
-Ben
October 2, 2020 at 2:14 pm #217699it is just a 3hp feed 24/1 gas-oi feed 90 grade oil in the gear case choke… pull the starter cord close the choke 🙂
October 3, 2020 at 12:53 am #217723I agree with Crosbyman, regardless of what it states on the motor or in the literature. Do not use 50:1 fuel to oil ratio. Please use 24:1 fuel to oil ratio. That is about 5 to 6oz oil to 1 gallon of gas. Your motor has plain bearings and there are ton of 3hp Evinrude/Johnson outboards that are prematurely worn out due to lack of oil. Yes, it will seem to run fine on 50:1, but its life will be short lived. Trust me, I am speaking the gospel according to AOMCI wealth of knowledge handed down through experience.
Use a good quality TC-W3 2 cycle marine oil.
Do not use 2 cycle oil meant for aircooled or weedeater motors.
The synthetic blends are biodegradable and produce a lot less smoke.
Here are a few examples.
Pennzoil Marine Premium Plus 1 qt. Synthetic Blend 2-Cycle Engine Oil
Evinrude Johnson Premium TC-W3® Mineral Formula
If you PM me your email address, I will send you an owners/service manual for 1968 Evinrude 3hp. It is the exact same motor except for the decals….lol
Cheers,
CajunOctober 6, 2020 at 10:48 am #217939Thanks y’all, I appreciate the info. I’ll make sure to mix at 24:1 going forward. The motor is a family heirloom, and we want to keep it running for as long as possible!
October 6, 2020 at 11:51 am #217946I feel more comfortable using 16:1 mix in these motors as 24:1 was meant more for motors with needle and roller bearings in them.
October 6, 2020 at 7:40 pm #217980I feel more comfortable using 16:1 mix in these motors as 24:1 was meant more for motors with needle and roller bearings in them.
I agree with Mumbles, especially if this engine is a valued piece of family history. But, 24:1 is surely much better than 50:1 on this plain rod bearing engine…
October 7, 2020 at 9:38 am #218026I feel more comfortable using 16:1 mix in these motors as 24:1 was meant more for motors with needle and roller bearings in them.
I always use 16:1 on my JW’s and Lightwins.
October 7, 2020 at 8:13 pm #218088I appreciate you guys backing me up on this. Was thinking about running leaner than 16-1 on a couple of ’66 model year 3hp motors. From your info, I’ll stay with 16-1 modern oils, while kicking in a little Lucas, Marvel, Ring-Free, or what ever is laying around.
