Home › Forum › Ask A Member › Johnson JHF 22S upper housing grommet 0205572
  • #254362
    neps989
      Hello everyone,
      I am working on a 1967 Johnson JHF 22S 3hp folding motor. I would like to replace the upper housing grommet part number 0205572, however it is no longer available. Does anyone know of a suitable substitute for this grommet? I don’t really know what the grommet looks like. I am hesitant to remove the original grommet without having a replacement on hand. Any suggestions ?
      Thank you
      Rob
      #254364
        JHF seems hard to find by looks like #42  on a 67 folding…. can’t you make one  by modifying a similar par
        • This reply was modified 4 years, 9 months ago by JACQUES.
        #254371
        neps989
          The part I want to replace is #42 in the diagram from marine engine. If I knew what the grommet was suppose to look like I may be able to modify another part and make it work. I have not removed the grommet from my motor. If I have to I will run it the way it is, just hoped to replace it while I was waiting for warm weather.
          Thanks
          Rob
          #254377
          mike n
            I have 1 that a havent put in my johnson yet. I can take a picture of it tomorrow. The flat surface is thicker than a standard grommet. I think a 317372 with the flat surface(some dont have the flat surface), might work if you glue a rubber washer to it
            mn
            #254382
            mike n
              I think this is same size but top part is thicker on 205572. Maybe glue rubber washer to top?
              mn
              #254387
              mike n
                If i have 317372, i will take picture of that also and measure
                mn
                #254388
                neps989
                  Thank you, that would be a big help.
                  Rob
                  #254419
                  mike n
                    317372 is on left. 205572 on right. They look the same size. Outer and inner diameters are only a couple thousandths different. The flat part that seals against the surface of lower unit that folds is 5/32 thinner on 317372. Maybe you can find a 5/32 piece of rubber to cut out and glue to it. Not sure what kind of glue. Maybe another member can give advice. Maybe super glue,weatherstrip adhesive,marine silicone. Just a suggestion. Good luck
                    20220211_120029
                    20220211_120111
                    20220211_120214
                    mn
                    • This reply was modified 4 years, 8 months ago by Mumbles.
                    #254428
                    neps989
                      Thank you for the pictures and the information. After seeing what the part looks like along with the information you provided, I am sure I can make something that will work.
                      Thanks again,
                      Rob
