Home › Forum › Ask A Member › Johnson HS 15 flywheel removal
  • #8337
    1957evinrude
      What is the best way to remove flywheel from a 1940 HS 15 Johnson
      #65472
        If the threads are long enough in the
        flywheel nut and its not all beat up
        from being hit with a hammer in
        the past all you’ll need is a bolt.
        https://www.youtube.com/watch?v=RWgE9XiIBnk
