Home › Forum › Ask A Member › Johnson HD-25 Low Speed Insert Lead Seat
  • #54835
      Garry, I believe I have the same information in the manual, but
      glad I reviewed yours, as I don’t remember reading that
      when you drive in a new insert with a lead seat installed,
      you’re suppose to drill out the lead seat with a 5/32"
      bit.
      Makes me wonder if the new lead seat doesn’t
      have a hole, or it does, but it needs reamed out
      after being "squashed"?
      Thanks!
        The lead seats arrived today. They’re little lead buttons
        that need the hole drilled after installed and seated.
        Unfortunately, I think it would be best to do this
        when the crankcase is "split", to avoid lead shavings
        ending up in the crankcase, and / or accidentally
        drilling into the crankshaft.
          Thanks Buck. I might attempt to make some now with the given dimensions.
