Home › Forum › Ask A Member › Johnson HD 25 impeller
  • #6493
    damart299
      Latest purchase is Johnson HD 25. Looking for impeller, seals for lower unit, and leads on where to start?
      #54000
        This is the prop shaft seal I bought for my HD-25.
        http://www.ebay.com/itm/292041222545?_t … EBIDX%3AIT
        The seal for the drive shaft is not available, and whatever is down that
        hole doesn’t look like a normal seal, so I left it alone.
        Regarding the impeller, not sure, buy try
        Brian Wilcox
        Call 810-794-7685 before 8 pm est please.
        Or email
        Baron0418@att.net
        please note the B must be a capital
        bkrsdoz
          The impeller is behind the prop under the cover that can be removed. It is a wobbler type impeller. Ken Hall has originals in stock.
