Home › Forum › Ask A Member › Johnson FD-12 Won’t Run
Viewing 6 posts - 41 through 46 (of 46 total)
  • #275078
    olcah
      Nice, nice job!  Looking and running like new.
      #275079
        I forgot to say thanks to all of you who responded with feedback on my original running problems – much appreciated.
        1982 Evinrude 25hp
        #275081
          Sounds good Bob, but it’s “crying” to get on a boat and go wild!
            Yes, it is.    I think it might be a real screamer.
            1982 Evinrude 25hp
            #275088
              OK, after replacing the defective fuel pump and installing new OMC/BRP coils, I’m declaring victory.   Seems to run good now.   You’ll notice in the video that after tweaking the carb adjustments, the low speed needle knob needs to be moved to point downward toward the scale and at the very end of the video, the high speed needle was a little loose and opening richer and just needed the packing nut tightened up a bit.   Final carb adjustments will be done once it gets on a boat.
              https://www.youtube.com/watch?v=FTsDbD03vHg
              Sure sounds nice now.  Perhaps the diaphragm was messed up in that original fuel pump creating a crankcase leak to that cylinder causing the lean spit.  Never argue with success, now get out and show it off!
              #275094
                Been an interesting and informative read with
                the end result being your ready for spring.
                Pretty good timing I’d say.
