Home › Forum › Ask A Member › Johnson FD-10 parts
  • #6032
    63lstrition
      I am working on restoring a siezed FD-10. From what I understand, this model was made only one year by Johnson before it was turned into an 18 hp, and it was previously made as an Evinrude model. My favorite place to look for part numbers, Marineengine.com, does not have any parts listed for the FD-10 and its sister models that year. Looking for some assistance to track down the correct part numbers vs assuming that I can make something from a 55 Evinrude 15 hp work.
      I might need new rings unless we can free them without breaking them. New crank seals, gaskets, coils, and an impeller. Everything else is pretty much there or we won’t know we need it until the rebuild.
      It was actually in pretty good shape once we broke it loose. No rust and very little pitting. Bearings were all good. Just a little honing of the jugs. I figure we put it back together and give the carb some TLC that it will go live.
      Any help on part numbers / sourcing and general rebuild advice would be appreciated
      #50295
      63lstrition
        I need a prop for it too. Forgot about that with its other issues.
        #50297
        David Stanton
          For the prop, new ones are available at good prices at http://propcopropellers.com/evinrude—johnson.html. Scroll down to this catagory:
          Evinrude – Johnson
          15hp, 18hp, 20hp, 25hp 53-77
          Pin Drive
          (not thru hub exhaust)
          #50304
            These motors have the same 2.375" bore as the ten horse motors and use the same 378416 piston rings. The head gasket is P/N 203247. Heck, here’s the parts manual showing the original P/N’s.
            #50308
            63lstrition
              Perfect!!!!! Thanks!!
              #50328
                For parts a wanted ad here on the forum will get you about the best service you could hope to find!
                #50330
                Steve D
                  quote Mumbles:
                  Mumbles, thanks a lot for posting all these nice parts manuals in pdf.
