Home › Forum › Ask A Member › Johnson Evinrude Reeds
  • #220595
    Matthew Pieklik
      On the 10 thru 35 or 40 HP 50’s 60’s Johnson Evinrude models, they use the petal reeds on the intake. I found they make them out of brass or a spring steel. I found this because I had an 18 Hp that I could not get to idle properly. I had 1 of each type reed on the plate. Apparently , They flex at different rates. I was either lean or rich. Once I put 2 of the same metal reeds in, It had a perfect idle. My question is , is there any advantage with brass over spring steel reeds or visa versa?
      #220621
      Matthew Pieklik
        Well, I know some one replied to this message but it disappeared.What up?
        #220631
          Yeah, I replied to it earlier. I’d like to know what happened to it to!
          The Poof Poof gremlins are back at it again.
          • This reply was modified 5 years, 12 months ago by Mumbles.
          #220652
            If that’s true, that is an amazing observation. Since I bring parts motors back from the dead all the time, I will be aware of that. When you got the motor, were the reeds already mismatched or was that something that you had tried yourself? I wonder if the steel one was out of a 25, which uses a whole slew of subtlety different parts than a regular old 18.
            #220659
            Matthew Pieklik
              The motor was that way when I got it. It was driving me crazy, Just could not get it to idle smooth. I don’t know what possessed me to pull the intake plate off, but once I saw the different color reeds, I was on to something.
              #220820
              76-j
                “My question is , is there any advantage with brass over spring steel reeds or visa versa?”
                I’m 77 years of age; ‘ been working (involved) with 2 cycle outboard motors for 6 decades. I’ve yet to see or feel any reeds made of brass.
                Conclusion – Brass reeds are as rare as Hen’s Molars ?!
                #220821
                Matthew Pieklik
                  Not sure what they are. They look like brass in color but apparently not. What are they made of?
                  #220828
                    A magnet will rule out brass in a hurry.
                      The brassy looking reeds are made out of beryllium copper.
