Home › Forum › Ask A Member › Johnson/Evinrude 3hp Compression?
  • #5106
    pike10
      Hello, I have a number of Johnson/Evinrude 3hp outboards from the mid 1950s to the early 1960s that will be a winter project to make as many complete runners as possible. What is the low end of the compression range as well as the high end, like new compression? Thank you.
      #42919
      wedgie
        75 -80 psi is considered good
