Home › Forum › Ask A Member › Johnson CD-16
  • #38091
      http://www.youtube.com/watch?v=EY2HrEdp5vg
      here is a similar the impeller job … no big deal.. just get a gasket for the base and I think the carbon seal can be an issue better replace it if suspect.
      #38092
        http://www.youtube.com/watch?v=SVOedhzPP7M
        dropping the lower unit on a similar engine
        #38111
        Doug Wilson
          would agree with crosbyman while its apart go ahead and replace the seal not expensive and right there when the power head is off.
          Doug
          turned off?
          #38245
          grover
            Yes, you do have to remove the powerhead. Here’s a link to a video I made a few years ago:
            https://www.youtube.com/watch?v=SVOedhzPP7M
            #38246
              If you try to change the impeller without removing the powerhead, chances are you’ll end up with a bent driveshaft, a bucket full of parts or another donor motor. 🙁
              #38310
              theodore
                Oh man, that guy had a rough day.
