Home › Forum › Ask A Member › johnson cd-12 tilt lock operation
- This topic has 9 replies, 4 voices, and was last updated 7 months, 3 weeks ago by
Sam M..
March 17, 2026 at 9:55 am #309952
how does a cd-12 tilt lock work?
March 17, 2026 at 12:16 pm #309975on my CD11 tilt lock locks DOWN in reverse only hence the name REVERSE LOCK
if you are looking for a tilt UP lock there is none see manual page 392… a short piece of dowel or 2×2 on a small chain works great ! 🙂
free downlaod for oldies print and bind locally or store on your PC or laptop
https://www.socalaomci.com/library/johnson_service_manual_10th_edition.pdf
March 17, 2026 at 1:42 pm #309986Tilt up lock is achieved by tightening tilt bolt until engine stays up on its own
March 17, 2026 at 4:07 pm #310007So starting procedure on stand to counteract the pull rope force is to start in Reverse or use a dowel or a block of wood?
March 17, 2026 at 5:14 pm #310031no reason to starting reverse if the engine works ok if the tilt is tight enough has suggested by Michael the engine will stay down …
dowel is ok trailing if the engine needs to stay up securely .
March 17, 2026 at 8:13 pm #310074Thanks, JACQUES and Michael for you knowledge transfer. I have only had the motor for 6 Days and I cleaned the carb on Saturday, and Started it on Sunday. Next is the leaking gear case for which I ordered the Sierra kit. Only 3 days needed to get the Johnson to run. I have spent 10 months to get a Ted Williams/Sears 7.5 hp (McCulloch) to run and the Marvel-Shelber carb has whipped me. Johnson outboards are loads easier to work on.
March 18, 2026 at 12:31 am #310118sealing the GC is not hard but…tricky. Doing a few helps so check utubes . the spaghetti is tricky..consult the manual in the link provided changing oring is tricky to on the shift shaft.
if you are going to do a good job replace all seal ( drive shaft prop shaft shifter rod seal when all done and closed up do a GC pressuretest to see if it will hold around 10psi for 10 minutes.. perform a vacum test also her are a few utubes
https://www.bing.com/videos/search?q=Danbar+pressure+test&cvid=6944a0ce5cec48c2a5cf8d7b99823568&aqs=edge..69i57.13358j0j1&pglt=43&PC=U531&ru=%2fsearch%3fq%3dDanbar%2bpressure%2btest%26cvid%3d6944a0ce5cec48c2a5cf8d7b99823568%26aqs%3dedge..69i57.13358j0j1%26pglt%3d43%26FORM%3dANNTA1%26PC%3dU531&view=detail&mmscn=vwrc&mid=144AD90360F195315D84144AD90360F195315D84&FORM=WRVORC
https://www.youtube.com/watch?v=GCkpGD4bgDI
Vintage Outboard Lower Unit Gearcase Shift Rod Seal Replacement Johnson / Evinrude / OMC Part 2
March 18, 2026 at 12:35 am #310120https://www.bing.com/videos/search?q=Danbar+pressure+test&cvid=6944a0ce5cec48c2a5cf8d7b99823568&aqs=edge..69i57.13358j0j1&pglt=43&PC=U531&ru=%2fsearch%3fq%3dDanbar%2bpressure%2btest%26cvid%3d6944a0ce5cec48c2a5cf8d7b99823568%26aqs%3dedge..69i57.13358j0j1%26pglt%3d43%26FORM%3dANNTA1%26PC%3dU531&view=detail&mmscn=vwrc&mid=144AD90360F195315D84144AD90360F195315D84&FORM=WRVORC
March 18, 2026 at 12:46 am #310124March 18, 2026 at 12:21 pm #310241So starting procedure on stand to counteract the pull rope force is to start in Reverse or use a dowel or a block of wood?
Just put one hand on the motor to keep it from tilting up as you start it. Same for on a boat.
Also, when running the motor on a stand, it must have water. It should submerge the impeller. Maybe you know this already but I wasn’t sure when you said stand not barrel..
Don’t forget about checking/changing the impeller! Many rubber impellers go bad over time.
