Home › Forum › Ask A Member › Johnson a
Viewing 4 posts - 31 through 34 (of 34 total)
  • #301623
    NATHAN KILLIAN
      US Junior Member
      I know that there is another forum thread about Johnson A’s now, but I checked the coil with a multimeter and got NO reading at all. Should I be looking to do a coil swap, or are there replacement coils that are easy to find?  Otherwise I may just try to find a parts motor to rob the coil off of.
      #301650
      GARY
        With some work you can replace the coil with newer OMC coils.The easiest thing to do is find a replacement from a another A model.Try an ad in the website classifieds or contact either Doug Penn or Jon Koranda,both are in the membership directory.
        #301714
          You can tell by my testing devices, I’m the last guy that should be giving advice on electronics.  But I have learned – to check the secondary, on a 2 spark coil, you test between the 2 spark plug leads. If you’re using a digital meter, it needs to be set on 20 K ohm scale.
          coil-test-XYZ
          #301739
          NATHAN KILLIAN
            US Junior Member
            I did that but got no reading at all, so I am looking to replace it.
