Home › Forum › Ask A Member › Johnson A-45 Head Gasket
  • #2216
    steveh
      Hi All!
      I’m working on this Johnson A-45. I took the cylinder head off to make for easier cleaning of the cylinder head itself, and parts of the motor below it. At first I thought it had no head gasket, and I thought that to be strange. However, when I looked closer, it appears a gasket was made out of old newspaper?!?
      What actually should be used?
      I have no manual or parts diagrams. It would help if someone has one they could share.
      Thanks!
      Steve.
      #21715
      wedgie
        Someone just posted this link the other day. 🙂
        http://www.joeoutboard.com/manuals/johnson-manuals.html
        http://www.joeoutboard.com/resources/Ma … -VR-XR.pdf
        http://www.joeoutboard.com/resources/Ma … 1-1927.pdf
        Here’s Art S’s website that might be helpful
        http://www.oddjobmotors.com/tt3_johnson … uffler.htm
        #21721
        lotec
          The A-45 doesn’t have a cylinder head gasket. I think what you are refering to is the cylinder base gasket. They were made from a brown craft paper that was impregnated with shellac. You can make an exact replacement using a brown paper grocery bag and painting each side with shellac. Then trace the outline using the cyl base and your old gasket. Cut and install!
